axulsuv Posted February 11, 2007 Report Share Posted February 11, 2007 I was poking around and came across hebo's website and they now show a hydralic clutch conversion kit for older bikes .... I was just wondering if anyone has ever used one on a 240 pro , and if it makes that big of differance when my clutch arm is already lengthened 1/2 an inch or so . ( the bikes , not my left one !) Glenn Quote Link to comment Share on other sites More sharing options...
lee harris Posted February 11, 2007 Report Share Posted February 11, 2007 The hebo bits are certainly plush but are you still in the spirit of things Glenn? Does your clutch lightener move the top and bottom out a half an inch. If not, do that first...top and bottom lee Quote Link to comment Share on other sites More sharing options...
bilco Posted February 12, 2007 Report Share Posted February 12, 2007 Bill pye has done a nice little clutch conversion to one of his 200 twinshock's a very cute job,one finger operation. He had it at the malvern bike show last year.not sure if his doing it this year but if he is he might have the bike there, worth taking a look at it. Quote Link to comment Share on other sites More sharing options...
andy m Posted February 12, 2007 Report Share Posted February 12, 2007 Hey Bilco Axulsuv will be keen if he goes to Malvern, he lives in the USA. Malverns good but it aint that good. Hell of a way to go to try out a clutch. Quote Link to comment Share on other sites More sharing options...
bilco Posted February 12, 2007 Report Share Posted February 12, 2007 Thank's bo,sorry axul. It show's it can be done without going hydralic though. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 13, 2007 Author Report Share Posted February 13, 2007 Lee ; yes my cable mount has been moved the same amount I lengthed the arm, I also have a differant spring on the arm . My clutch works for me fine w/ my standard 2 finger grip that I've used most of my life. And acording to ITSA modern twinshock class rules : drum brakes , aircooled , twinshocks ! kinda a run what ya brung class , as long as it meets that criteria , and is SAFE to ride !!!! kinda leaves the door open !!! And Bil & BD ; is his 200 hydralic ? I was just curious if anyone has seen or used the kit hebo sells ... Thanks , I think I'll save my money for now ... But do you think I can put a built tl250 engine in my spare 240 chassis ? (and I realize the drive is on the wrong side !) Glenn Quote Link to comment Share on other sites More sharing options...
bilco Posted February 13, 2007 Report Share Posted February 13, 2007 (edited) Axul. Bill's 200 clutch is 100% cable. I'll give you a brief description of the set up. As you probaly know on the 200's there's an adjuster that screw's into the top of the engine casing,that was removed and with the engine split he drilled down into the casing where the adjuster used screw into, and then made up a shaft that would slide down into the casing,i can only guess he used a circlip to secure the shaft at the bottom,back up top he had two little arm's fitted either side of the shaft, there was a length of cable from your handlebar's down to your new arm ,and the other arm would hold a piece of cable going to the original clutch arm bolted to the engine.As you operate the clutch the new shaft turn's in turn. That's a very basic description and as you could imagine there's a hell of alot of work involved there. think it's a game of experimenting untill you get it right,but it can be done and you would'nt know the diffrence between cable or hydralic. one finger operation. hope that explain's it clear enough. Edited February 13, 2007 by bilco Quote Link to comment Share on other sites More sharing options...
axulsuv Posted February 14, 2007 Author Report Share Posted February 14, 2007 I think I can picture what you described ... I think I'll stay with my lenghtened arm and mount for now !!!! Glenn Quote Link to comment Share on other sites More sharing options...
lee harris Posted February 14, 2007 Report Share Posted February 14, 2007 http://www.classic-trial.de/hontic.htm have a look at a german 200 tlr200. click about a bit there are more pictures lee Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted February 14, 2007 Report Share Posted February 14, 2007 Hey Lee - Those are neat pictures - must say the guy who built the Honda twin/Fan - did a great job - how did it run? Quote Link to comment Share on other sites More sharing options...
lee harris Posted February 16, 2007 Report Share Posted February 16, 2007 The guy rides it regularly on four stroke twin shock trials here in northen germany. It it very competitive. XL 185 motor, bored I fink to 206cc, tlr 200 primary drive and a cl125 final. 4th and 5 th are the same. The guy did it really well. Hope my 340 will look half as good. Lee Quote Link to comment Share on other sites More sharing options...
Ful Posted January 5, 2024 Report Share Posted January 5, 2024 On 2/13/2007 at 5:58 PM, bilco said: Axul. Bill's 200 clutch is 100% cable. I'll give you a brief description of the set up. As you probaly know on the 200's there's an adjuster that screw's into the top of the engine casing,that was removed and with the engine split he drilled down into the casing where the adjuster used screw into, and then made up a shaft that would slide down into the casing,i can only guess he used a circlip to secure the shaft at the bottom,back up top he had two little arm's fitted either side of the shaft, there was a length of cable from your handlebar's down to your new arm ,and the other arm would hold a piece of cable going to the original clutch arm bolted to the engine.As you operate the clutch the new shaft turn's in turn. That's a very basic description and as you could imagine there's a hell of alot of work involved there. think it's a game of experimenting untill you get it right,but it can be done and you would'nt know the diffrence between cable or hydralic. one finger operation. hope that explain's it clear enough. Hi Bilco. Have you any reference more about this clutch mod by Bill Pye ? i looked for this man on the internet: Bill Pye, Frankfield Garage, but just find it is definetively closed. Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
