No Spark - Help?
lc -rev3
Did a very wet trial today but had retire after the bike conked out at the end of the 1st lap. I had been getting shocks from the kill switch before it died so binned the switch and tried a new plug but still no spark.
Just wondered if anyone has any ideas worth checking before I take to the dealers.
cheers
I would seem sensible to check things like the spark plug lead aswell as the spark plug cap, check that nthing is earthing on the frame anywhere.
The electrics are pretty simple to get your head round, so it shouldn't be too much bother to pull the wires out and check most connections. If that fails, see if your dealer will lend you a CDI unit (beta UK did for me) and see if it is that, same for the coil and even stator. Try changing the easy parts first. You should beable to diagnose the problem with a few hours tinkering.
Bob
