stuessenhigh Posted April 5, 2004 Report Share Posted April 5, 2004 (edited) Hi all, My nuts keep coming loose at the rear of the bash-plate...(near the footpegs). I've even tried using thread lock..but no diffference. Does anyone else get that problem?? ANy ideas to solve it?? Its a Rev 3 2002 model Edited April 5, 2004 by StuEssenhigh Quote Link to comment Share on other sites More sharing options...
pa. Posted April 6, 2004 Report Share Posted April 6, 2004 You may have damaged threads in the frame. Try retapping them or getting Helicoils inserted. Quote Link to comment Share on other sites More sharing options...
anyhill Posted April 6, 2004 Report Share Posted April 6, 2004 have you tried using nylock nuts? Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted April 7, 2004 Author Report Share Posted April 7, 2004 HIYA.. Yep...I know ONE of the threads is damaged, but I dont think I could put it right myself. What are nylock nuts??...I'd love to know...and would love to know where to get 'em if they'll help the problem. CHeers Quote Link to comment Share on other sites More sharing options...
anyhill Posted April 7, 2004 Report Share Posted April 7, 2004 Stu, i should have been more clear (was p****d when adding the comment!). They are nylon nuts that are only used once then thrown away. See here: http://www.screwfix.com/app/sfd/sea/search...=1&cd=1&x=0&y=0 Dunno if you can link to the above, if not go to screwfix.com and search for nylon nuts. If it's the same bolts (countersunk?) as the techno, i think it should be an M8. You could also try using two nuts, (dunno if you would have enough room or a long enough bolt) one acting as a locking nut! Quote Link to comment Share on other sites More sharing options...
j@mes Posted April 7, 2004 Report Share Posted April 7, 2004 (edited) the bolts dont go all the way through the frame so nylon nuts or any nuts cant be used. and aren't countersunk but think are m8 nylon nuts are like ordinary nuts but have a strip of nylon in which locks on to the bolt Edited April 7, 2004 by J@mes Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted April 7, 2004 Author Report Share Posted April 7, 2004 YEah...unfortunately anyhill, the Rev3 ones are NOT countersunk (BIG mistake I reckon)..techno way was better. I think that is why I'm having the problem, 'cause I keep catching the head of the nut on the corner of rocks..('cause I'm not very good at big steps!!) ALso..James is right, the nut doesn't go all the way through the frame. SO....if there are any more ideas...please keep 'em coming Quote Link to comment Share on other sites More sharing options...
beta boy Posted April 7, 2004 Report Share Posted April 7, 2004 have you tried using super glue or locking washers Quote Link to comment Share on other sites More sharing options...
clarkp Posted April 8, 2004 Report Share Posted April 8, 2004 Stu - first of all, I can't believe no one's made any cracks about your 'loose nuts' - I couldn't resist, even as obvious as it is... Why are you shying away from just retapping the holes to the next larger size bolt? That way you can tap the holes to fit whatever style bolt you want. You might even try countersinking the bash plate to receive a countersunk head screw / bolt so your rock encounters won't have as much of an adverse affect. You can buy the tap and get a piece of aluminum to practice on... drill a slightly smaller hole and run the tap through to get the feel of it. Quote Link to comment Share on other sites More sharing options...
j@mes Posted April 8, 2004 Report Share Posted April 8, 2004 i think they would be better countersunk. doubt this would work but what about a spring washer between the head of the bolt and the bashplate. I recently took my bashplate off on my 02 beta and the bolts didn't seem that tight. I had to file a bit of the head of one of the bolts because it had been hit but where i live there aint many stone steps just mud. I will have to keep checking those bolts now i've taken them out once. Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted April 8, 2004 Author Report Share Posted April 8, 2004 Yeah James....you should definately keep an eye on them..else they'll pop out without you knowing it. Clarkp...yep you're right...and retapping the holes is something I HAVE to learn..especially with this Beta which seems to have a few threads that feel like they're made of butter.....SO...watch this space....I'll try and get the correct tools and get practising. CHeers all for you help Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted April 9, 2004 Report Share Posted April 9, 2004 Countersinking a hole is very easy to do with a large drill bit. It's also easy to screw up by going too deep if you're using a hand drill. Use a drill press or find someone who has one. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted April 9, 2004 Report Share Posted April 9, 2004 Oh, yeah...if you buy a Heli-coil kit, it comes with the proper drill bit, tap, etc. It's really easy. Especially with aluminum because it taps so easily. Quote Link to comment Share on other sites More sharing options...
pa. Posted April 12, 2004 Report Share Posted April 12, 2004 The thread is M8 1.25mm pitch. You could replace the standard bolts with Socket Head Cap bolts. The ones for the front of the bash plate are 25mm and the rear 15mm long. Quote Link to comment Share on other sites More sharing options...
amiller Posted April 12, 2004 Report Share Posted April 12, 2004 Just so you know there is such a thing as Nylock bolts. They actuall have a nylon plug machined into the lower threaded portion of the bolt. Work great. Aaron Quote Link to comment Share on other sites More sharing options...
