petedad Posted April 7, 2004 Report Share Posted April 7, 2004 Does any one know if the rear shock on a 03 sherco is rebuildable as petes is making a strange squishy noise on rebound but is still damping. suspect power washing caused the problem. if it comes down to it and a new one is needed will the 04 fit ,heard its longer but a better shock. cheers lads. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 7, 2004 Report Share Posted April 7, 2004 Same length I think, I do believe Falcon can repair them. Quote Link to comment Share on other sites More sharing options...
petedad Posted April 7, 2004 Author Report Share Posted April 7, 2004 cheers nigel ,you wouldnt have a contact number or address would you. Quote Link to comment Share on other sites More sharing options...
wonder boy Posted April 7, 2004 Report Share Posted April 7, 2004 Check that the bearings and also there seals around the shock area are ok and working fine. There could be a lot of water in them and when you push the shock down your pushing ou the waterout of the bearings. But this is only a guess. Gavin Hope you fine the problem. But so times its not a big a job as you think. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 8, 2004 Report Share Posted April 8, 2004 Falcon always advertise in the back of TMX. Quote Link to comment Share on other sites More sharing options...
sherco pete Posted April 8, 2004 Report Share Posted April 8, 2004 cheers nigel.im using the strange noise in my shocker as an excuse for my resent poor riding. ill get the shock taken out and see if i can see a problem if not ill get it sent away. Quote Link to comment Share on other sites More sharing options...
