craig lee scott Posted February 19, 2007 Report Share Posted February 19, 2007 (edited) Hello! I'm after some short levers blades for the clutch and front brake. The ones I'm after are shown in the image below. I found these on ebay (here) but it states Gas Gas (not pro) I have a 04 Raga 300 so I'm guessing they won't fit. Does anyone know if they will or not? If not could someone let me know where I could get some short levers from, I searched through Ebay and used Google and Froogle but just don't seem to be able to find any. Thanks, Craig....... Edited February 19, 2007 by Craig Lee Scott Quote Link to comment Share on other sites More sharing options...
shercrazy Posted February 20, 2007 Report Share Posted February 20, 2007 TRY RYPUSA.COM, THEY STOCK ALL KINDS OF LEVERSAND STUFF, MOST LEVERS ARE UNIVERSAL, IF THAT DON'T HELP TRY BOTTLERUNXTREME.COM, THEY ALSO STOCK ALL THAT STUFF ALSO, HOPE THIS HELPS!!! GOOD LUCK!! Quote Link to comment Share on other sites More sharing options...
seandellear Posted February 20, 2007 Report Share Posted February 20, 2007 (edited) The fromnt brake lever will fit! As the adjuster is offset but The clutch one will only fit if the master cylinder is a the large version like the front brake! If it is the standard small master cylinder it will not as this is meant to be in-line with the lever blade itself! (This might be the other way round though! ) Hope this helps clear things up a bit! I personally prefer the standard levers as I find anything else changes the feel of the clutych and makes it haevy! Take it easy! Edited February 20, 2007 by seandellear Quote Link to comment Share on other sites More sharing options...
