sherco_man Posted February 23, 2007 Report Share Posted February 23, 2007 Hi All, Does anybody know where i could purchase some anodised bolts for my sherco because i can't seem to find them anywhere? Thanks Quote Link to comment Share on other sites More sharing options...
Andy Posted February 23, 2007 Report Share Posted February 23, 2007 I've corrected the title of your forum topic as "Anodised Blots" made you look like a bit of a muppet. Quote Link to comment Share on other sites More sharing options...
sherco_man Posted February 23, 2007 Author Report Share Posted February 23, 2007 I've corrected the title of your forum topic as "Anodised Blots" made you look like a bit of a muppet. Whoops, Thanks for that. Quote Link to comment Share on other sites More sharing options...
bikespace Posted February 23, 2007 Report Share Posted February 23, 2007 (edited) I've corrected the title of your forum topic as "Anodised Blots" made you look like a bit of a muppet. Well done - stopped him looking a muppet If we all shut up about it nobody will notice eh I've had a few off Ebay - these lot were quite good, but have a search and there's loads of them about. Anodised bolts Edited February 23, 2007 by bikespace Quote Link to comment Share on other sites More sharing options...
essex rider Posted February 24, 2007 Report Share Posted February 24, 2007 hyperbolt.co.uk is where i got mine from...... What colour you after??? Quote Link to comment Share on other sites More sharing options...
sherco_man Posted February 24, 2007 Author Report Share Posted February 24, 2007 Thanks for the help. Im after red ones if possible. Do you know which bolts will fit best to a sherco? Quote Link to comment Share on other sites More sharing options...
ham2 Posted February 24, 2007 Report Share Posted February 24, 2007 (edited) Thanks for the help. Im after red ones if possible.Do you know which bolts will fit best to a sherco? Not red surely?? Tell us where the bolt goes and we tell you what type you need. Edited February 24, 2007 by HAM2 Quote Link to comment Share on other sites More sharing options...
sherco_man Posted February 24, 2007 Author Report Share Posted February 24, 2007 Thanks very much. Ill do my best to get the part names right. The bolts i would like are those that surround the crankcase and water pump cover . And also those that surround the flywheel cover. Thanks again for the help. Quote Link to comment Share on other sites More sharing options...
essex rider Posted February 24, 2007 Report Share Posted February 24, 2007 (edited) USE THIS Click on the technical info, then aluminium specifications Use the table for SOCKET HEAD CAP SCREW. Then take the bolt out and measure the length of the bolt. Edited February 24, 2007 by Essex Rider Quote Link to comment Share on other sites More sharing options...
sherco_man Posted February 24, 2007 Author Report Share Posted February 24, 2007 Thanks ill do it now. Quote Link to comment Share on other sites More sharing options...
furse Posted February 24, 2007 Report Share Posted February 24, 2007 You could try Demon Tweeks web site or Pro bolt. But RED on a Sherco ! Make sure you put some copper grease on the alu bolts before installing. Quote Link to comment Share on other sites More sharing options...
sherco_man Posted February 24, 2007 Author Report Share Posted February 24, 2007 I have a 2007 sherco and it has little parts of red on it. I thought it might look good but on the other hand blue might look better. Quote Link to comment Share on other sites More sharing options...
