crossman Posted February 25, 2007 Report Share Posted February 25, 2007 i'am new to the forum and could not find anything on this topic. I need a new cdi for '86 tlr200 reflex, oem part is no longer avaliable and I wanted to know if anybody knowes of an alternitive. Quote Link to comment Share on other sites More sharing options...
peterb Posted March 24, 2007 Report Share Posted March 24, 2007 Hi crossman, I'm not sure if I can help. I thought the TLR200 had ign points? Does your model have electronic ign? If so, and your electronic advance/mapping "box" has failed, then I would imagine a similar unit could be found from a Honda road model, GL125/145 or similar or one of the many trail bike versions, XR200. Thought these would have been more popular than the TLR. The actual mapping may be slightly different but you could counter that a little by adjusting the static timing - by adjusting the ignition sensor pick up coil position. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
