Forks
scottt
Just noticed today my forks are flush with the top yoke (04-250) but my mates bike (05-250) there is about 15-20mm protruding through the top yolk.
So are they both right? Was that a difference between the 04 and 05 models? Or is 1 wrong?
Scott.
Neither are wrong, you can adjust the steering by moving the forks through the yokes, try it and see how you like the changes, from memory the Sherco forks have engraved marks every 5mm so you can return to a setting.
Sliding the yokes down the forks 5mm makes the feel steering quicker but more inclined to 'tuck under' in tight turns
What GII says is true.
Road riders drop their yokes down the forks to steepen the steering angle and give a faster turn-in on corners.
Dropping the yokes also pitches the whole bike forwards and puts more weight on the front, which reduces the tendancy to wheelie when hard on the throttle. Look at a drag bike, those guys use tie down straps to compress the front suspension and get as much weight over the front as possible.
As for the bike wanting to tuck-under, a steeper steering angle inherently reduces stability...
I say if your happy with how the bike feels, dont worry about it. If not, you can always experiment with the height of the yokes until you find something thats good for you.
Thank you all for your replies.
My mates bike must have 10mm sticking through the yokes as i can see 1 groove about 5mm above the yoke, I have noticed when we try uphill sections my bike does tend to wheelie more than his, which often ends up with me struggling to get the front down before i loop it, i just put it down to different riding styles, it might be but i'll set my forks the same as his and see if that makes any difference.
Thanks again,
Scott.
