leroy Posted February 26, 2007 Report Share Posted February 26, 2007 was out on my bike over the weekend up charlton and war riding down near the via-duct, i was crossing the river when suddenly the front wheels slipped and the bike went under. i got the bike ticking over but as soon as u reved it a little it wud just stall eventually i got the revs up a lil and got it up in the carpark. i then finally got the bike reving as normal. i got the bike home and cleaned the carb out and flushed the tank out and i put the carb back together and now when i start the bike and leave it ticking over petrol starts pourin out off the over flow, now my bike (montesa cota 311) has 2 float and 1 is is 1/4 and the other is 5/8 and ive tried them both ways and it still put petrol out of the overflow and the floats slide up and down ok and the carb is clean any ideas plzz liam Quote Link to comment Share on other sites More sharing options...
the addict Posted February 26, 2007 Report Share Posted February 26, 2007 (edited) Sounds like the fuel/shut off needle is dirty or worn causing it not to close the fuel flow off. It usaully only shows on low revs as higher revs tends to get rid of the fuel from the float. Give it a really good clean and check fuel flow/shut off is working with the float bowl off whilst the carb is out of the bike. Easy part to buy and replace. Edited February 26, 2007 by Betarev3 Quote Link to comment Share on other sites More sharing options...
leroy Posted February 26, 2007 Author Report Share Posted February 26, 2007 ok cheers but do you have any idea where i might be able to find out wich float goes at wich side Quote Link to comment Share on other sites More sharing options...
betatrials99 Posted February 26, 2007 Report Share Posted February 26, 2007 One thing that might be worth trying or looking at is the floats. If somehow they have developed a small crack at the join or something a little bit of petrol may have got into them (yet seemingly unoticable) causing them not too rise to where they should and therefore the overflow pipe will p*** water out. (have seen it once in a bike - very rare) If that is the case tho keep them in a dry place and try to squeeze it out. When its all owt just super glue the seam, leave it too dry and fit it again. Or just buy new floats. Quote Link to comment Share on other sites More sharing options...
drop5 Posted February 27, 2007 Report Share Posted February 27, 2007 if the bikes had a good soaking dont forget to change the oil. change it and run the bike for a few minutes,drain it again if it comes out clean ok if not repeat til its clear. Quote Link to comment Share on other sites More sharing options...
barrybaines Posted February 27, 2007 Report Share Posted February 27, 2007 causing them not too rise to where they should and therefore the overflow pipe will p*** water out. were did you get the converter too make the bike run on water? Would save me loads of money Quote Link to comment Share on other sites More sharing options...
betatrials99 Posted February 27, 2007 Report Share Posted February 27, 2007 oooo yea my mistake - petrol! damn it. Quote Link to comment Share on other sites More sharing options...
leroy Posted February 27, 2007 Author Report Share Posted February 27, 2007 so any of you have any idea where i myt find out which float goeas at which side? cheers liam Quote Link to comment Share on other sites More sharing options...
