Changing Oils
oke boy
Hi, the clutch on my 290 works with rotax engine is dragging on start up then it frees itself but it is becoming more notacible during the days ride. Have been told changing the oil in the clutch may help. Q. how do you do it as i dont know much about bikes and what oil should be used? Also how do you change the gear box oil and again what sort of oil is best. Any pics showing what to do would be great or is there a manual or book which is good at helping out.
Thanks Steve
p.s how much oil should go into each area?
