daggs888 Posted March 2, 2007 Report Share Posted March 2, 2007 All the gasser boys use this......does it work ok in the 4rt ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 3, 2007 Report Share Posted March 3, 2007 Erase that thought. Never think it again unless you want a push bike! Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted March 3, 2007 Report Share Posted March 3, 2007 Unless I'm very much mistaken, you need engine oil in a four stroke. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 3, 2007 Report Share Posted March 3, 2007 4 stroke oil for the engine, ATF for the clutch/gearbox. Have run 3 315's on ATF and now 4rt. Bike will start in gear and can set of straight away when engine is cold with onl 2 to 3 seconds of drag. If you search Montesa forum there are many discussions on this. Quote Link to comment Share on other sites More sharing options...
masso Posted March 4, 2007 Report Share Posted March 4, 2007 4 stroke oil for the engine, ATF for the clutch/gearbox. Have run 3 315's on ATF and now 4rt. Bike will start in gear and can set of straight away when engine is cold with onl 2 to 3 seconds of drag.If you search Montesa forum there are many discussions on this. ......................I too have ridden with atf with good results, BUT...nothing works as well as the recommended ELF oil period!!! Quote Link to comment Share on other sites More sharing options...
