ka2 Posted March 3, 2007 Report Share Posted March 3, 2007 Hi I just installed the float bowl extension and changed the main and pilot jet (to 140, 27.5), on my 07 Rev 3 250. I set the float height at 10mm per the instructions. It seems to run better, at least in the backyard, but I don't think I have things quite right yet. I'm sure that there is a link somewhere on this site that has more detailed instructions than I had (minimal), but I couldn't find it. Any help would be appreciated. Also, when I took the carb out, I noticed that the breather hose that runs on the pipe side of the carb was kinked shut. When I tried to unkink it I noticed that it was heat fused. This isn't "stock" is it? Thanks ken Quote Link to comment Share on other sites More sharing options...
rlracer Posted March 4, 2007 Report Share Posted March 4, 2007 Do a search here you should find what you are looking for in detail. The tube next to the carb just needs a little bend in it. Quote Link to comment Share on other sites More sharing options...
