Clutch Slave Advice Needed
graham
Gas Gas txt pro 05
i stripped down the clutch slave and am unsure which way the spring goes back, or at least the plastic tube insde the spring. does anyone know? there is a short plastic tube that either goes in the engine side or teh casing side of the spring.
thanks for reading
Graham
UK
Hello Graham,
The plastic piece is a spring guide that fits inside the slave spring inside the clutch casing, larger diameter on the plastic goes into the case first.
Use an ATF rated to Dexron III, 500ml to refill.
Bye, PeterB.
