fanticmartin Posted March 6, 2007 Report Share Posted March 6, 2007 My Fantic 307 has lost you use of its clutch ..... All external connection are all ok . Which side engine cover do i need to take off ect to check out first.. Thanks Martin Quote Link to comment Share on other sites More sharing options...
lee harris Posted March 9, 2007 Report Share Posted March 9, 2007 what do you mean by that lost its use...wont lift and separate or slips? If it slips, try using atf, look also for cable freeplay. If it slips badle, take the left cover off, block the clutch drum using a folded rag and remove 5 screws and spings to replace. If it wont lift since its been standing. put it in 6th gear with the engine off, pull the lever in and jerk the bike backwards a couple times until it separates. When it does, you are on your way! lee Quote Link to comment Share on other sites More sharing options...
