2006 250pro
spike2450
Hi
Has anyone got any ideal ( initial ) settings for the front forks.
There appears to be quite a few different views on the quantity of gearbox oil to use. I've always used dexron3 and am initially going to use 450mils, any help would be great.
Had one ride on the 250 Pro and i'm very happy with her!! if only she was blonde!!!!
Hi Spike,
If it is an 06 PRO then you need 550ml oil, about 50ml stays in the box when draining so you would be fine with 500ml. Always use a mineral oil in the box, never synthetic. 10 weight mineral or an ATF rated to Dexron III is fine.
We always leave the forks set up as they come out of the crate so unable to help you with any adjustment set up.
Fit a 10T gearbox sprocket and use a water proof grease on the linkage bearings.
Bye, PeterB.
