andys Posted March 9, 2007 Report Share Posted March 9, 2007 Hi Guys, Do you have to remove the rear wheel on 2003 2.5 Sherco to check/change the pads? Also what coolant do you use? cheers Andy Quote Link to comment Share on other sites More sharing options...
sr34 Posted March 9, 2007 Report Share Posted March 9, 2007 yes remove wheel for pad change coolant is 9. Fill the cooling system to the top inside collar of the radiator with a 50/50 mixture of Ethylene Glycol and water. We recommend Maxima Coolanol. to the best of my knowledge anyway if you get stuck try here http://www.sherco-moto.com/wayne_corner.html Quote Link to comment Share on other sites More sharing options...
