macdaddy Posted March 12, 2007 Report Share Posted March 12, 2007 OK ....its a "00 rev3 250 I was riding along and it felt kinda boggy ..wouldnt pull clean off the bottom end(this bike has always pulled down low VERY clean) so I tried to clean it out (you know whack it open) thats when I noticed it wouldn't rev out now this bike has not been used that much this year so I figured fresh gas and a new plug would do th trick...noop so the carb must be mucked up ..took it to work and gave it a through cleaning....still no luck broken reed ....nada scored piston and or a stuck ring... negative so what is this mystery disease?? timing? coil? HELPPPPPP this all started out of the blue (IE .no I hadn't been messing with it) not to mention its always been stone reliable thanks troy Quote Link to comment Share on other sites More sharing options...
rlracer Posted March 12, 2007 Report Share Posted March 12, 2007 Maybe the stator ? Give Beta USA a call in the morning and talk to Ron. Quote Link to comment Share on other sites More sharing options...
shercrazy Posted March 12, 2007 Report Share Posted March 12, 2007 yes, my guess is the stator, or try cleaning the screen in your petcock, does it still start? or is it done? the beta stators usually act up when the bike is hot, then are o.k. when you let it sit. (thats a good sign of it going bad) but bogging out on the bottom sounds like fuel deficiency, its starving at low revs cause there's not enough vaccume to suck fuel through a clog (dirty petcock) but when the slide opens there is enough vaccume to supply the fuel. but it's just a fix to a similar problem i had with my beta. (plus it doesn't cost $300.00 to fix) hope this helps....................................................john Quote Link to comment Share on other sites More sharing options...
max1956bikes Posted March 12, 2007 Report Share Posted March 12, 2007 is airfilter nice and clean?try giving it a rev without it. Quote Link to comment Share on other sites More sharing options...
macdaddy Posted March 12, 2007 Author Report Share Posted March 12, 2007 the air filter was "OK" ..but I did pull it off and there was no change ,maybe even a little worse (fuel starving??? i,ll look at the screen) it will start and run just not in 1 or 2 kicks ... mid range it still runs reasonable thats whats so confusing heat seems to make no difference Quote Link to comment Share on other sites More sharing options...
beta bodger Posted March 12, 2007 Report Share Posted March 12, 2007 I recon it will probably be the stator or the cdi. This happened on my bike same model and year and it turned out to be the cdi. Quote Link to comment Share on other sites More sharing options...
mad4it Posted March 13, 2007 Report Share Posted March 13, 2007 Sounds silly but try putting in a new spark plug this can also cause these symptoms plus it's the first cheap step to take. Quote Link to comment Share on other sites More sharing options...
gasgasssser Posted March 13, 2007 Report Share Posted March 13, 2007 He already did Quote Link to comment Share on other sites More sharing options...
