How Much Play?
gasgasssser
I`ve decided to renew the dog bone bearings on my 04 290.I`ve noticed that the bolts which go through the (new)bearings and bolt one end of the dog bone to the frame, are quite loose,just a normal kind of fit,not what you would call a presision fit.Similar at the opposite end. The bolts are new so i`m assuming this is normal.
What do you guys think?,also should there be any play at all when its all bolted back together?
Cheers :D
i've just changed the dog bone bearings on mine & found exactly the same! there is just lil bit of play between the bush and bolt. I did find tho, that when i bolted all the linkage up there was no problem and the bearings seated fine.
Edited by gaz
Thanks Gaz,i was thinking on those lines myself.Just needed to hear it from someone else,Cheers :D
