the addict Posted March 14, 2007 Report Share Posted March 14, 2007 Dads off line for now, kids messed up the computer . The clutch on his 4rt was perfect for the first few weeks but is now next to impossible to start the bike in gear because it is pulling? Hes been using the Elf oil and has bled the system through so it not a cable/cylinder problem thats causing it. Has anyone had any problems like this and what can be done mod wise to sort it out. He does have Hyspin AWS32 high performance mineral hydraulic oil which is very thin like the Elf, anyone tried it? or is there a better oil to stop the dragging. Many thanks for any comments or answers Quote Link to comment Share on other sites More sharing options...
4rt guru Posted March 14, 2007 Report Share Posted March 14, 2007 elf . what year ? 05 crap ,fit mitani . 06 better some minerals eat the glue so be carefull. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 15, 2007 Report Share Posted March 15, 2007 I have 05 4rt with 06 clutch. Use ATF, starts 90% of the time when in gear, 100% when warm. Takes 5 sec to disengage when cold. But pepole say elf is best???? Quote Link to comment Share on other sites More sharing options...
munch Posted March 15, 2007 Report Share Posted March 15, 2007 gearbox is noisier with atf in, elf is best . i have fitted different steel plates too . is it an 05? Quote Link to comment Share on other sites More sharing options...
gimp Posted March 15, 2007 Report Share Posted March 15, 2007 I used castrol SLX 0w40 in gearbox and engine- it is a first rate oil- clutch was excellent. Quote Link to comment Share on other sites More sharing options...
the addict Posted March 15, 2007 Author Report Share Posted March 15, 2007 Thanks for all the comments and advice guys I will let Rod know tonight Quote Link to comment Share on other sites More sharing options...
munch Posted March 18, 2007 Report Share Posted March 18, 2007 no problem Quote Link to comment Share on other sites More sharing options...
gii Posted March 20, 2007 Report Share Posted March 20, 2007 Munch, Did you just change the metal plates or did you fit Mitani friction plates too? I'm thinking of fitting Mitanis on my 05 bike but if it's worth changing the metal plates I'd rather do it all at once. What metal plates did you fit? Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted March 20, 2007 Report Share Posted March 20, 2007 I have recently replaced the std steel plates with Jitsie steel plates and and ATF oil with the recommended HTX740 oil. I feel after about 10 hours of riding that the clutch action have been improved. I don Quote Link to comment Share on other sites More sharing options...
munch Posted March 20, 2007 Report Share Posted March 20, 2007 as above , used the jitsie plates. mitani are good too. ive fitted both. Quote Link to comment Share on other sites More sharing options...
fantic303 Posted March 21, 2007 Report Share Posted March 21, 2007 (edited) I had the original steel plates replaced with the jitsie plates, but no result the clutch keeps on dragging even with the recommend HTX740 oil. Now that i have replace the friction plates for new ones the clutch is terrific. The motor starts in gear and its easy the get it in the free. I think that the problem is that the friction plates become too smooth so that they stick together. Changes with other or larger master brake cilinder will not have result. Edited March 21, 2007 by fantic303 Quote Link to comment Share on other sites More sharing options...
