Cub Crankcase Breather.
trialsrfun
Which is the best type of crankcase breather for a Trials Cub, some people leave the original with the small hole inside the r/h engine case.
Another method blocks this off and then a pipe is fitted from the screw in bung on top of the crankcases, I am told that one can also be fitted on to the head but I have yet to see this type.
So which method works the best.
Its the crankcase that needs to breath, the last two methods you mention both work fine, a breather tube stub can easily be fitted to the bung cap (1 inch long X 3/16 I/D x 1/4 O/D tube - alloy/brass) on top of the crankcae, you then fit a 1/4 I/D plastic tube long enough to tuck under tank, the second option is to fit a similar size breather tube to the either rocker cover, the plastic tube is then fitted and the much shorter tube again tucked under the tank - both methods work fine, I favour the first option being closer to the crankcase.
Hope this helps Brian H
certainly the breather using the cap in the top of the crankcase should have the most benifit and I followed this route using fuel type piping, having looked at a number of trials bikes since this method has been confirmed as the most popular, however pipes of much bigger diameter appear to be the norm with the max i have seen been 15mm ID, what differnce do they make unsure.. but making them up only took an afternoon and cost pennies,, music to any trials fan
Edited by totalshell
My initial choice of breather was the one on the top of the crankcases but I am concerned that the pumping effect from the underside of the piston might send oil up the pipe and out to atmosphere a sort of total loss system if you follow me, Is there any likelyhood of this occuring.
never had a drop out of my breather on the crankcase. although mine is an open pipe as described above. I am going to swap to the type of breather pipe found on royal enfields which have the open end 'nipped' up so that nothing can get 'sucked 'in
Which bung on the top of the crankcase are you talking
Vinnied
33333333333333333333333333333333333333333333333333333333333333333333333333333333
3
3
3
was going ( and will still try to post a pic of mine)
best wishes
