Piston Rings!
mil
Hi, thanks to the help of some of the guys on the forum I have placed a clunking in the engine to a need to de-coke it. I've stripped it all down and indeed it needed some work! All done now and ready to go back on. The problem is seating the cylinder over the 2 piston rings. I'm sure their is a tool for this to squeeze them in, but any tricks to make it easy??!
Thanks
Alan
It really should be quite easy make sure you have the rings in the correct place with locating pin in the gap
have the piston at BDC you should be able too get the barrel over the first one then check the second ones position squeeze with finger and thumb and barrel on?
I assume here that you took the rings off the piston and cleaned all the crap out from the ring slots?
Thanks for the reply- I did clen it all out but as I squeeze them together they want to spring back and hard to slide on. I will try BDC and take rings off to clean all crap out completely.
I was thinking of a big fat zip tie around them. As you slide barrel down it would slide on and you could just nip the ties off?
Thanks for the help Brian.
Got it all buttoned up today- the problem was that I hadn't located the rings with the split either side of the small 'notch' in the groove. This stopped them compressing completely. I only realised this when I took the rings off and cleaned the grooves out etc...!The only problem now is getting one of the manifold bolts in as you need a ball ended allen key as the header pipe runs right over the top of it! Keeps wanting to cross thread but I'll get there.
Cheers fellas for the help. But snow for 3 days solid here means it'll stay in the garage for a while!!
