ecd Posted March 24, 2007 Report Share Posted March 24, 2007 I just drained the gearbox fluid and thought I'd give the Dexron 3 a try. How much are you guys putting in. I have a 2001 TXT 280 and I drained about 700 ml out. Thanks Quote Link to comment Share on other sites More sharing options...
peterb Posted March 24, 2007 Report Share Posted March 24, 2007 Hi ecd, You would be fine with 650 to 700ml of Dexron III rated ATF after draining the old oil. Remember to drain the oil when warm as any metallic particles remain in suspension and will therefore drain away. From new, the older GG motors had a spec for 750ml, some of the oil remains after draining. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
