dr nick Posted March 25, 2007 Report Share Posted March 25, 2007 I`ve got a 315r and have recently bought and fitted some Hebo footpegs. They make a big diffrence to grip compared to my old worn standard ones and are a bit wider, but, I have noticed that when I kick my bike over, the kickstart catches on the footpeg and sometimes gets stuck. Although it obviously doesnt stop the bike from firing up, it is quite annoying and is causing damage to the kickstart lever, I`m not sure if any internal damage is being done. Anyone else had this problem? if so , what did you do to solve the problem....apart from buying new pegs Quote Link to comment Share on other sites More sharing options...
bucki3 Posted March 25, 2007 Report Share Posted March 25, 2007 I've got a 4RT, fitted raptor pegs with 10mm hangers and have the exact same problem, I took the path of removing a shaving off the kickstarter and it managed to clear, others heat the peg and manipulate it out the way ( 4lb hammer nomally sorts it! ) Quote Link to comment Share on other sites More sharing options...
fantic303 Posted March 26, 2007 Report Share Posted March 26, 2007 I have also the same problem, Jitsie hangers with Hebo pegs. By the 4RT you don't have push to hard on the kickstart Quote Link to comment Share on other sites More sharing options...
