beamish owners club Posted March 29, 2007 Report Share Posted March 29, 2007 I have a 2006 200 Pro that needs front wheel bearings. I am assuming that they are the same front and rear like previous models? I know the TXT (non Pro) takes the 6004-2RS bearing - does anyone know the bearing number for the Pro models and are they all the same? Quote Link to comment Share on other sites More sharing options...
hrc1 Posted March 29, 2007 Report Share Posted March 29, 2007 Different fronts...6905. Cheap on Eblag... Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted March 29, 2007 Author Report Share Posted March 29, 2007 Different fronts...6905.Cheap on Eblag... Thanks Mike, any idea of the number of the rear bearings? Quote Link to comment Share on other sites More sharing options...
pandelboy Posted March 29, 2007 Report Share Posted March 29, 2007 (edited) its on the rubber seal 6004-2rs (rears) Edited March 29, 2007 by pandelboy Quote Link to comment Share on other sites More sharing options...
coxy Posted March 29, 2007 Report Share Posted March 29, 2007 front and rears are different i would defo get some from ebay they are alot cheaper than from gas gas or your local trial shop and they last just as long if not longer Quote Link to comment Share on other sites More sharing options...
jse Posted March 31, 2007 Report Share Posted March 31, 2007 Don't forget to carefully pry off the rubber seal on each side and pack them with waterproof grease, then re-install the seals. Most bearings are high-speed rated and as such come with little lubrication inside so if you pack them they will usually last a lot longer with the lighter duty we put them under. Cheers. Jon Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted April 1, 2007 Author Report Share Posted April 1, 2007 Don't forget to carefully pry off the rubber seal on each side and pack them with waterproof grease, then re-install the seals. Most bearings are high-speed rated and as such come with little lubrication inside so if you pack them they will usually last a lot longer with the lighter duty we put them under.Cheers. Jon Thanks Jon, that's good advice. Cheers, Jim Quote Link to comment Share on other sites More sharing options...
beamish owners club Posted April 1, 2007 Author Report Share Posted April 1, 2007 front and rears are different i would defo get some from ebay they are alot cheaper than from gas gas or your local trial shop and they last just as long if not longer Thanks for your help on this. I have a shed load of 6004-2RS that I bought in bulk from the USA for my other Gassers, just need to stock up on the 6905-2RS for the fronts of my Pro's! Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted April 2, 2007 Report Share Posted April 2, 2007 Would these fit ??? ebay link Quote Link to comment Share on other sites More sharing options...
badass76 Posted April 7, 2007 Report Share Posted April 7, 2007 Would these fit ??? ebay link yes Quote Link to comment Share on other sites More sharing options...
