gaby Posted March 31, 2007 Report Share Posted March 31, 2007 2001 2.9 Warm after 45 minutes of section riding. 2nd gear, clutch in, coasting downhill. rpm's mysteriously spiked, like the throttle was pinned. Once rpm's spiked there was no response from throttle input. Clutch stopped working (I held front brake and rear wheel spun in dirt) Kill switch had no effect. Seemed like 15-20 seconds at full revs, then the engine shut off abruptly. I waited a few minutes and restarted. Everything seemed to be in working order, clutch, throttle, kill switch. I rode sections for another 45 minutes with no issues. I often give rides to my little boys and would hate for this to happen again with one of them on board. Thoughts??? Quote Link to comment Share on other sites More sharing options...
ask greeves Posted March 31, 2007 Report Share Posted March 31, 2007 (edited) What happened could be known as the 'Rudolf effect' this probably first took place around 1858. In your case the crankcase probably filled with fuel, the engine being hot, and pumped the fuel through the transfer ports and ignited through the charge being ignited by pre ignition. In Rudolf Diesel's case he almost blew himself up. He was the first to prove that fuel could be ignited without ignition. During decents specially in low gears, make sure engine is not over used as brake (can easily over rev and overun), use rear brake to slow rear wheel rotation. Edited March 31, 2007 by ask greeves Quote Link to comment Share on other sites More sharing options...
copemech Posted April 4, 2007 Report Share Posted April 4, 2007 This is also what happens when you do not check the airbox and filter after washing the bike! Quote Link to comment Share on other sites More sharing options...
29r Posted April 4, 2007 Report Share Posted April 4, 2007 Space time continual comes to mind . Possible close encounter with the TWILIGHT ZONE ! Quote Link to comment Share on other sites More sharing options...
copemech Posted April 4, 2007 Report Share Posted April 4, 2007 Right after "Beam me up, Scotty!" it was a close encounter with the washing machine to tidy up the undies!!! Been there, Done that! Quote Link to comment Share on other sites More sharing options...
29r Posted April 5, 2007 Report Share Posted April 5, 2007 Okay , I'm a bit thick . Wasn't sure it to be an April fools thing . What does a car wash have to do with it all , especially causing the clutch to become inoperative ? Quote Link to comment Share on other sites More sharing options...
copemech Posted April 5, 2007 Report Share Posted April 5, 2007 When these things happen, it is the BRANE(not brain) that becomes inop! Much like people stepping on the gas, thinking they are pressing the brake harder in a car! Happens more often than you would like to know! Waiting for a report to reveal how much water and dirt is still in the airbox! Quote Link to comment Share on other sites More sharing options...
gaby Posted April 5, 2007 Author Report Share Posted April 5, 2007 Well, I can't always say this about the undies, but the airbox and filter are clean as a whistle. I'm not sure what to think about all these theories. I have done another 4 hours of section riding since posting and the bike runs like a top. It was probably gremlins anyway. They have been known to attack small dogs and empty bottles of rum in and around my home. Damn Gremlins... Quote Link to comment Share on other sites More sharing options...
