06 250 Pro - Fork Oil Change
spike2450
Hi
I want to replace the fork oil on a 2006 250 pro, ( black forks / presumably ally ), is there a definative start to finish guide, i have searched on this forum and there seems to be different views especially on the amount of oil etc.
Any help / opinions are appreciated.
The Marzocchi's need to be set by oil level only, rather than volume like the Gas-Gas forks due to the cartridge designs. The oil levels for the Zoke's are different depending on if the upper tubes are steel (earlier type) or aluminum (later types). Oil level is set with (1) cartridge bled of air, (2) fork collapsed and (3) spring removed.
Cheers.
Jon
