subira Posted April 15, 2007 Report Share Posted April 15, 2007 Anyone know, or got a good picture showing the angle of the rear brake hose where it leaves the rear master? On an 06 Pro. Been replacing the piston/spring/seal and have set it about 90 degrees but doesn't look just right to me. I'm thinking it needs about 10-15 degrees more down toward the swinging arm, but then it seems to rub the shock spring. Any ideas? Quote Link to comment Share on other sites More sharing options...
munch Posted April 16, 2007 Report Share Posted April 16, 2007 left at 90 degrees Quote Link to comment Share on other sites More sharing options...
peterb Posted April 19, 2007 Report Share Posted April 19, 2007 Hi Subira, All confirmed, I had a look at my 06 Raga. Looking from above, the hose exits the master cylinder at right angles, in towards the shock. Yes, the hose will foul the shock spring (All do from new), tie the hose out of the way with a cable tie around the rear engine casing so that the spring will not rub the hose. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
