superhondaman Posted April 16, 2007 Report Share Posted April 16, 2007 Replaced the oil seal behind the srocket on TLR 250 but the new one is still weeping oil, so got another one and its still leaking! any suggestions? Is there some magical way of pushing it in. Quote Link to comment Share on other sites More sharing options...
mad4it Posted April 17, 2007 Report Share Posted April 17, 2007 Yes if you get a peice of tube slightly larger on the ID and just under on the OD push the seal on the g/box shaft and drive it in,this will keep the seal from distorting on assembly which will lessen the risk of it leaking.Hope this is of help to you! Quote Link to comment Share on other sites More sharing options...
g4321 Posted April 17, 2007 Report Share Posted April 17, 2007 Did you check that the bearing is not worn? If the seal was changed and the bearings were worn it would still leak. Quote Link to comment Share on other sites More sharing options...
honda_tlr Posted April 17, 2007 Report Share Posted April 17, 2007 mine used to do this , it had loads of washers packing it out , got a new sprocket now tho.(and a seal of course) Quote Link to comment Share on other sites More sharing options...
