Rear Brake Master Cylinder Tip!
jonathan collier
Having just spent a frustrating 2 hrs in the shed fitting a new seal kit to the rear master cylinder I thought I'd pass on a tip to the sherco riders here. The circlip which retains the brake cylinder piston had rusted away letting the piston fall down too low and releasing brake fluid. It was really difficult to get out, probably should have dropped the swing arm out to do it.
The tip : slip the little rubber boot off the bottom of the cylinder and slap some grease in there to stop the clip rusting!
