Correct Gear Oil For Gas Gas 280
manxgasser
Hi there,
From brand new, these have 550ml in the gearbox.
When re-filling, about 50ml or more stays behind, so best to re-fill with 500ml.
If there is too much, it always exits the breather anyway.
Change the oil often as it lubes both main bearings aswell as the clutch and gears, say every 30-40 hours use.
Use only mineral oil, 10 weight or an Auto Transmission Fluid (ATF) rated to Dexron III.
Bye, PeterB.
  • 3 weeks later...
