mont4rt Posted April 29, 2007 Report Share Posted April 29, 2007 Is there any one that can help I have got an 05 4rt that destroys spark plugs in two hours riding and starts miss firing back firing you name it its doing it the plug is black in soot .Each time I put a new plug in it lasts for two hours agian. I put a new coil and lead and cap but still the same problem. Quote Link to comment Share on other sites More sharing options...
gasgasssser Posted April 29, 2007 Report Share Posted April 29, 2007 Dont know much about the RT,but a sooty plug usually means you`re running rich Quote Link to comment Share on other sites More sharing options...
cadman Posted April 30, 2007 Report Share Posted April 30, 2007 Is there any one that can help I have got an 05 4rt that destroys spark plugs in two hours riding and starts miss firing back firing you name it its doing it the plug is black in soot .Each time I put a new plug in it lasts for two hours agian. I put a new coil and lead and cap but still the same problem. How long are you warming it up for? Suggest at least couple of mins of idle, I also have tacho/hr meter so I know when it's up to 1800 rpm ie warm but easy way is to wait until radiator fan kicks in, then you know it is warmed up. It takes me at least that long to put boots etc on anyhow. When starting and during warm up DO NOT touch the throttle. ie the old 2st blip the throttle during warmup is a NO NO, it will just foul the plug with black soot. Oh and run the 5 not the 6 plug if your in cold climate. HTH Quote Link to comment Share on other sites More sharing options...
motojojo Posted April 30, 2007 Report Share Posted April 30, 2007 If the hotter plug and no rev in warming up don't help, your floats might not be shutting off the fuel flow. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 30, 2007 Report Share Posted April 30, 2007 I have 05 which when if not allowed to warm up on tick over will start to mess up plugs. Start and leave well alone for 2 mins. Also when I boiught mine s/hand from Sandifords they expressed how important correct tickover is. If set too low the ingnition and fuel pump is not getting enough charge and will stress the system resulting in bad plugs. hope this helps Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 30, 2007 Report Share Posted April 30, 2007 PS Always stop engine with kill switch was also informed. This stop engine in correct sequence? Also if it wont start was told to kick engine over very slowly with throttle open, press kill button to reset ignition map, snap throttle closed ready for start. Seems to work!! Quote Link to comment Share on other sites More sharing options...
mont4rt Posted April 30, 2007 Author Report Share Posted April 30, 2007 PSAlways stop engine with kill switch was also informed. This stop engine in correct sequence? Also if it wont start was told to kick engine over very slowly with throttle open, press kill button to reset ignition map, snap throttle closed ready for start. Seems to work!! Thanks I will try and reset the ingnition map I have all ways warmed the bike up I have had the bike from new and had no problems until now. Quote Link to comment Share on other sites More sharing options...
