wasmeneh Posted May 1, 2007 Report Share Posted May 1, 2007 I just picked up an 86 TY 350. I haven't been able to locate an owner's or service manual for it yet. Does anybody have handy the capacities of the Tranny and forks. I always like to change out fluid's when I pick up a bike. I've been refered to B&J Racing for parts, any other good sources? Would the 85 and 86 service manual be about the same, I found a reprint of the 85 TY350 service manual available at Yamaha dog. Thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
scott_king Posted May 1, 2007 Report Share Posted May 1, 2007 (edited) Hi I may be wrong but I think 95% of the bike is the same as the TY250. Only really jets in the carb, piston, cylinder head and a few frame mods separate the bikes. If you cannot find a TY350 manual a 250 one from a similar year will be nearly as good. A few manuals come up on eBay. Or you may be lucky and get a service CD from the internet with all the manuals including the TY350. Engine oil: Manual says 800ml but yamaha importer recommended 750ml Fork oil: 300cm3 (10.6 imperial fluid oz) each - 10w 30 motor oil (normal fork oil feels rubbish so use engine oil) These measurements are from a 1989 TY250 but they should not differ from your bike. Hope this helps Scott Edited May 1, 2007 by scott_king Quote Link to comment Share on other sites More sharing options...
paul w Posted May 1, 2007 Report Share Posted May 1, 2007 hi scott, does the trick with the engine oil work on the ty175 as i am in the process of re-building my forks. cheers paul. Quote Link to comment Share on other sites More sharing options...
kevin j Posted May 1, 2007 Report Share Posted May 1, 2007 where are you located? Bruce anderson site has most of the CJ modification's listed. The easy, std stuff is flywheel trim, clutch extender, fork springs I also added bar risers, disc front brake and need to lower the pegs. Lots of ebay stuff available in the US I can send you a file of notes. kcj Quote Link to comment Share on other sites More sharing options...
wasmeneh Posted May 1, 2007 Author Report Share Posted May 1, 2007 KCJ, Located in Wilmington, NC. Lot's of relatives in St. Paul. Mike [\quote name=kevin j' date='May 1 2007, 09:21 AM' post='123651] where are you located? Bruce anderson site has most of the CJ modification's listed. The easy, std stuff is flywheel trim, clutch extender, fork springs I also added bar risers, disc front brake and need to lower the pegs. Lots of ebay stuff available in the US I can send you a file of notes. kcj Quote Link to comment Share on other sites More sharing options...
scott_king Posted May 2, 2007 Report Share Posted May 2, 2007 hi scott, does the trick with the engine oil work on the ty175 as i am in the process of re-building my forks. cheers paul. Hey Paul From my experience it makes them harder and feels more progressive. It says use engine oil in the manual but I still tried proper fork oil and found it too soft. Hope this helps. Scott Quote Link to comment Share on other sites More sharing options...
kevin j Posted May 2, 2007 Report Share Posted May 2, 2007 KCJ, Located in Wilmington, NC. Lot's of relatives in St. Paul. Mike if you ever get up here, contact me and we'll go riding. www.umta.org is Minnesota. WOTA is Wisconsin Quote Link to comment Share on other sites More sharing options...
wasmeneh Posted May 2, 2007 Author Report Share Posted May 2, 2007 KCJ,Located in Wilmington, NC. Lot's of relatives in St. Paul. Mike if you ever get up here, contact me and we'll go riding. www.umta.org is Minnesota. WOTA is Wisconsin Thanks, As for my search for a manual, I found a repro one on Yamadog. Mike Quote Link to comment Share on other sites More sharing options...
