phmx259 Posted May 1, 2007 Report Share Posted May 1, 2007 (edited) Hi have a 1996 Scorpa 250 with rotax motor . Out in fount yard playing when clutch started to slip. As I went around the house it got worst. Pulled in shop took apart an there it was plates was burn disk were gone .Called The trials Shop order new plates an disks .Put them in road for about 30 min. started to slip again .put new springs in same thing . put 6 springs in hard to pull lever but after about 20 min. slipping came back. need some help thank you all Edited May 1, 2007 by phmx259 Quote Link to comment Share on other sites More sharing options...
windfall Posted May 1, 2007 Report Share Posted May 1, 2007 Is it possible the hydraulic fluid needs replaced? If that's old and contaminated, it may expand when the motor heats up and cause the slippage. Quote Link to comment Share on other sites More sharing options...
