jonathan collier Posted May 1, 2007 Report Share Posted May 1, 2007 Just learning to ride the 290, 04 model. I'm experiencing a sort of over steer or tucking in of the front end during very tight, all most on the lock stops, turns. I've not fiddled with preload settings or damping (if there is any adjustment?) wondered if this could be dialled out? I ride novice B/C grade so no big steps or drop offs to contend with. Any advice appreciated. Quote Link to comment Share on other sites More sharing options...
coxy Posted May 1, 2007 Report Share Posted May 1, 2007 if your fork yokes are low try moving them up so the top of the top yoke is flush with the top of the fork top which should help you with the tucking under Quote Link to comment Share on other sites More sharing options...
copemech Posted May 2, 2007 Report Share Posted May 2, 2007 JC, if anything, Sherco's have never had a problem "tucking" on turns. If anything it is quite the opposite! Lean into the turn with your feet and straighten your inside arm while moving your weight(butt) outside! You can open up the steering a bit and roll properly through the turn! More lean, more turn! GO Practice! Quote Link to comment Share on other sites More sharing options...
vintagecota Posted May 2, 2007 Report Share Posted May 2, 2007 I was having the same problem when I started riding my "new" Cota 200. The front wheel just wouldn't stay on track, washing out or tucking under. Some local experts gave me the same advice, "Weight the outside peg", as Copemech just gave and PRESTO, problem solved. Now the bike turns amazingly, and with the practice Ive been getting the last few weekends, I can put the front wheel right where I want it and have it track right through a turn, even on very tricky roots and sidehills. Quote Link to comment Share on other sites More sharing options...
jonathan collier Posted May 4, 2007 Author Report Share Posted May 4, 2007 Thanks fellas willtry the peg weighting advice and check the position of the fork relative to top yoke. From memory its on the 2nd ring, not flush. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 5, 2007 Report Share Posted May 5, 2007 Most run them at 1-2 rings down, unless it is in the mud! Quote Link to comment Share on other sites More sharing options...
