albert Posted May 7, 2007 Report Share Posted May 7, 2007 does anyone have any advice on cleaning std 4rt clutch plates,also after returning rear shocker to factory setting.cheers. Quote Link to comment Share on other sites More sharing options...
gii Posted May 7, 2007 Report Share Posted May 7, 2007 Wash them in petrol, or buy some brake cleaner spray and use that, or buy the Mitani plates, they're really good and if you take them out and flog em on the bay when you sell the bike you'll recoup some of the cost of having a clutch that works properly. Rear shocker, standard settings: Spring free length: 133mm Spring length under pre-load: 126.5mm Adjuster setting: 10 clicks from "full hard" Source: 05 owners manual Quote Link to comment Share on other sites More sharing options...
