steam Posted May 7, 2007 Report Share Posted May 7, 2007 I often need the choke to start this bike when hot even thoughIi have set the float levels at 16mm by bending the two tangs that touch the float. Now i am wondering if I should have done some bending at the float valve end instead. If so , how? The bike starts easily from cold using the choke Quote Link to comment Share on other sites More sharing options...
coxy Posted May 7, 2007 Report Share Posted May 7, 2007 could be something to do with the mixture or try a new plug if youve had it in along time Quote Link to comment Share on other sites More sharing options...
motojojo Posted May 8, 2007 Report Share Posted May 8, 2007 Needs a larger start-up jet Quote Link to comment Share on other sites More sharing options...
peterb Posted May 8, 2007 Report Share Posted May 8, 2007 Hi Steam, Can you give me your jet sizes, needle and needle jet, needle clip position, pilot screw - how many turns out. These are usually good starting when warm. Not sure how you set your float tangs, turn carb upside down, float arms should run parallel to the carb body bowl mating surface. Is the carb a DellOrto PHBL 26. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
steam Posted May 9, 2007 Author Report Share Posted May 9, 2007 pilot jet increased to 38 starter jet drilled out to 1mm everything else as standard air screw approx 2 turns out--do not want to alter it as bike runs fine Quote Link to comment Share on other sites More sharing options...
peterb Posted May 13, 2007 Report Share Posted May 13, 2007 Hi steam, Had another thought. Does the bike have Ducati ignition, if so, I have noticed on a few bikes that the ignition pick up sensor is mounted a little too close to the outside of the magneto, leaving a tell tale scrape band on the outside of the mag. (When hot, the magneto expands and can contact the pick up if it is too close). There is room for a little adjustment to move the sensor away from the magneto. If the pick up was touching, the ignition system would have a hard time working properly. With a standard pilot size 30, the pilot screw would usually be around 3.5 to 4 turns out. Your 2 turns may be a little lean, but then you have put in a 38 pilot jet - check the mag. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
tomskiy Posted May 19, 2007 Report Share Posted May 19, 2007 Hi Steam, if your bike still has the Dellorto carb fitted, take the float bowl off the carb, place it upside down and as PeterB said the needle valve operating arms should be parallel to the face that the float bowl matches up to. When in this position, the measurement from the surface that the float bowl matches up to, to the top surface of the operating arms should be 18.5mm. Quote Link to comment Share on other sites More sharing options...
