charlie Posted May 9, 2007 Report Share Posted May 9, 2007 my fantic 300 dies when i open the throttle more than half way . it runs fine when cold and the choke on . any suggestions ? Quote Link to comment Share on other sites More sharing options...
isaacely Posted May 9, 2007 Report Share Posted May 9, 2007 my fantic 300 dies when i open the throttle more than half way . it runs fine when cold and the choke on . any suggestions ? Hi, it sounds to me like the main jet is blocked, you need to remove the float bowl and check for dirt or water, remove the main jet and blow through it to clear an obstuction. You should be able to see through the centre of the jet. Good luck Alan. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 11, 2007 Report Share Posted May 11, 2007 Or it may have a vacum leak !!!! Glenn Quote Link to comment Share on other sites More sharing options...
