axulsuv Posted May 10, 2007 Report Share Posted May 10, 2007 I just received a set of progresive fork springs in the post to go with my new falcon shocks and was curious as to which end of the fork spring is the top ? the tight wound end or the loose wound end ? or does it not make a differance ? Thanks , Glenn Quote Link to comment Share on other sites More sharing options...
mcman56 Posted May 10, 2007 Report Share Posted May 10, 2007 The tight wound end goes up. If it is at the bottom, there is more spring (weight) to move when the forks move but I don't know if anyone could tell. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 11, 2007 Author Report Share Posted May 11, 2007 Thanks , I found you are totaly correct ! and they also displace less oil that way too !!! Glenn Quote Link to comment Share on other sites More sharing options...
