mick annick Posted May 12, 2007 Report Share Posted May 12, 2007 Does anyone have an original rear axle spacer for a '75 MAR they could measure for me, or know where I can get one? My bike has a Miller flat sprocket conversion but I want to return it to the original dished sprocket so will need to find, or get made, the spacer to fit. Mick Annick Quote Link to comment Share on other sites More sharing options...
mick annick Posted May 15, 2007 Author Report Share Posted May 15, 2007 I thought at least Woody would've known... Mick Quote Link to comment Share on other sites More sharing options...
woody Posted May 15, 2007 Report Share Posted May 15, 2007 Missed this post originally so only just seen it. Don't know the size of the spacer unfortunately and it's been a long time since I had a bike with a dished sprocket as they just bend the spindles which are made from chocolate, all mine have the flat conversion. May have a wheel somewhere which has the spindle through it and is fitted with a dished sprocket so I'll have a look to see if the spacer is also with it and if so measure it. Could be a few days as it is buried underneath stuff at the back of the garage. Quote Link to comment Share on other sites More sharing options...
mick annick Posted May 16, 2007 Author Report Share Posted May 16, 2007 Thanks Woody, I knew I could rely on you! Mick Quote Link to comment Share on other sites More sharing options...
woody Posted May 20, 2007 Report Share Posted May 20, 2007 No, sorry Mick, thought I may have one still in situ on a spindle somewhere but no luck. All mine have the flat sprocket conversion fitted Quote Link to comment Share on other sites More sharing options...
mick annick Posted May 20, 2007 Author Report Share Posted May 20, 2007 Woody Thanks for looking, I'll have to track down a guy I know in Hampshire that's into Ossa's... Mick Quote Link to comment Share on other sites More sharing options...
mk1 Posted May 21, 2007 Report Share Posted May 21, 2007 what do you want the length?I can dig mine out from the back of the garage and measure it for you later in the week Quote Link to comment Share on other sites More sharing options...
mick annick Posted May 23, 2007 Author Report Share Posted May 23, 2007 mk1 Yes, it's just the length, got the remants that was cut down. mick Quote Link to comment Share on other sites More sharing options...
mk1 Posted May 26, 2007 Report Share Posted May 26, 2007 right,dug it out & it measures 38mm long(1"1/2),the inner diametre is 25mm and the outer 20mm if that helps Quote Link to comment Share on other sites More sharing options...
mick annick Posted May 28, 2007 Author Report Share Posted May 28, 2007 MK1 Thanks, with my old bit and this info I can get a new one machined. Mick Quote Link to comment Share on other sites More sharing options...
