125 Clutch Slip
penno350
My son's 04 125 works fine apart from a couple of recent trials where he has ridden a distance between sections pulling a high gear at which point the clutch has 'disappeared' it was slipping so badly. Once its left for a short while and its only ridden in and between sections for a short distance/lower gear everything is ok.
Does anyone have any experience of this and what should I potentially be looking at as a cure?
I had the same problem on a sherco 125
the engine breather was blocked
this was cleaned and the problem disapeared
hope this helps
cheers
