whiplash Posted May 17, 2007 Report Share Posted May 17, 2007 Hi all, Last July, I bought a beautiful Sherco two-cycle 2.9 (2004 or 2005 model). I have no manual, no dealer, and no idea how to start the thing. I had it going once this winter, but that, it seems, was sheer luck. I have never had or ridden a two cycle before, so they are strange creatures to me. Whether the choke lever was up or down seemed to make no difference while starting or riding, so I never figured out what the proper drill was for starting. It Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 17, 2007 Report Share Posted May 17, 2007 (edited) sherco moto website is helpful the better one is RYPUSA, go on there and see how you get on. Starting is easy, best get a new plug and fresh gas then choke up a few kicks and she will start, warm it up gently and then shut the choke off, away you go. 1 choke up to start 2 just a little throttle to start 3 no on switch 4 should be able to swap plug ok once loosened do it by hand? to take the tank off is one bolt, so if you are working on it do that? new plug and gas is the way to go. Check you have a nice spark? Edited May 17, 2007 by Nigel Dabster Quote Link to comment Share on other sites More sharing options...
whiplash Posted May 17, 2007 Author Report Share Posted May 17, 2007 Thanks so much, Nigel. I'll give it a try ASAP. fingers crossed! Whip sherco moto website is helpful the better one is RYPUSA, go on there and see how you get on.Starting is easy, best get a new plug and fresh gas then choke up a few kicks and she will start, warm it up gently and then shut the choke off, away you go. 1 choke up to start 2 just a little throttle to start 3 no on switch 4 should be able to swap plug ok once loosened do it by hand? to take the tank off is one bolt, so if you are working on it do that? new plug and gas is the way to go. Check you have a nice spark? Quote Link to comment Share on other sites More sharing options...
gasgasssser Posted May 17, 2007 Report Share Posted May 17, 2007 NEVER use any throttle to start.With the choke on you get a fast idle any way.Two or three kicks should be enough.Should be able to run without choke after 10/15 secs Quote Link to comment Share on other sites More sharing options...
whiplash Posted May 18, 2007 Author Report Share Posted May 18, 2007 Thank you gasgasssser, I think my leg will have recovered by this weekend, so I'll kick it some more using your advice, along with previous. I live in BC, so there's fantastic riding here. Can't wait!! Cheers, Whip NEVER use any throttle to start.With the choke on you get a fast idle any way.Two or three kicks should be enough.Should be able to run without choke after 10/15 secs Quote Link to comment Share on other sites More sharing options...
powellriver315 Posted May 19, 2007 Report Share Posted May 19, 2007 who are you riding with at the club? i am up in powell river mostly but anyone at the club will give you a hand. it's a great all ages sport you'll have no probs meeting similar ability riders. one good guy is burt 889 1750. have fun / Quote Link to comment Share on other sites More sharing options...
