Fat Bar On A Rev 3 2000
mikee
Depends on the top clamp on there to be honest. If the bottom half of the bar clamp is removable you can buy the correct size clamps easy enough to swap over and put new fat bars in.
If however (more likely) the top clamp is one piece with the bottom halves of the bar clamps you will need to either get it machined out? or you coould try fitting one from a 2007 model? Not sure if it will fit mind!
Better still you could get a VERY nice VMAR one :D
thanks for the replys guys,
I do have Up side down forks but the mounts are in two parts...
so are the holes all standard size????
Anyone have a link to the rethal site or anywhere escle to buy them..
The V-mar look the bizz, how do you rate them??? Are they avilable here in the uk.???
thanks
I had the V-Mar on my Beta and now on my Montesa, they are awesome but they don't make them for the USD forks :D
Edited by sirhc
What would help me on this one is if any of you who have either the standard fat bars or the renthal fat bars could give a measurement between to center of the holes on the clamps...
On our V-Mar top clamps, the spacing between the bolt holes on the bar clamp is 40mm (the bolts on either side of the handlebar), and the side to side spacing between the two bar clamps 80mm.
The diameter of the standard bar is 7/8" (0.875" or 22.225mm)
and the diameter of the fat bar is 1-1/8" (1.125" or 28.575mm)
Hope that helps.
Vince
V-Mar Racing
If you need more info I can probably post a dimensioned drawing or photo. Just let me know.
  • 3 weeks later...
