Aprillia Clutch
skid
My brother has a 1990 or so 240 climber. Whats the trick to pulling the clutch basket. It does not appear to be like a jap dirtbike where you can use a tool to hold the basket from spinning. The nut spins along with the plates inside the basket. How do you keep the motor from spinning so you can break the nut loose. btw is it a normal thread or reverse thread?
