slack Posted May 18, 2007 Report Share Posted May 18, 2007 Hi everybody, i've been keeping a check on my oil because my bike has been realy smokey.the last twice i've checked it (using the bolt under the kickstart) i've had to top it up.My question is how hard is it to split the casing,& is the water pump tricky to line up and will i have to split the engine to change the seal or will i be able to just pop it out & fit the new one. CHEERS. Quote Link to comment Share on other sites More sharing options...
