Floating Front Disc Brake Movement
sectionone
A floating front disc allows for side to side movement, but should there also be any up and down movement? Mine does and sometimes makes a clanking noise as well as not stopping well. Does the metal collar around the mounting bolts need to be replaced?
Hi there had the same problem on my 307 i replaced the cups as they had some wear. When the brake was locked you felt movement like the head bearings were going , it stoped when i changed the cups 6 i think without looking.Hope this helps
