graeme Posted May 21, 2007 Report Share Posted May 21, 2007 Hi I have just bought a jtx 270 1997 i think it has got a bottom end rumble, previous owner fitted new piston and ring i think it has loads of compression which backs this up I am interested at what my options are for a rebuild it has pay in fly wheel i must say i am new to the forum so not sure if you can give names of supliers i use a trials shop in stroud thanks graeme Quote Link to comment Share on other sites More sharing options...
copemech Posted May 23, 2007 Report Share Posted May 23, 2007 Let them put some new bearings and seals in it! Send them just the motor if you can, as most any reputable shop can do it quickly and get it back to you. Do you have local references? Quote Link to comment Share on other sites More sharing options...
graeme Posted May 24, 2007 Author Report Share Posted May 24, 2007 ive managed to get the engine out and split the casings one of the mains had lost its bearing retainer Con rod seams fine I will change mains and small end is their any others i should change whilst i am doing it the other seam fine but if they are cheap enough i mite as well do a proper job Quote Link to comment Share on other sites More sharing options...
copemech Posted May 25, 2007 Report Share Posted May 25, 2007 I'm no Gasser expert, but the only things that come to mind would be the seals on the water pump and possibly the output shaft(chain) gear, as these are common wear items on any bike over time. Quote Link to comment Share on other sites More sharing options...
peterb Posted May 27, 2007 Report Share Posted May 27, 2007 Hi Graeme, Best to replace both main bearings, make sure they are the correct clearence. Should be a type 6206 C3 - C3 being the clearence designator. Fit new crank seals and centre gasket. As copemech advises, it's a good idea to replace the water pump seal and quite likely the water pump shaft as these tend to groove out. There is a seal/shaft kit available for these. Don't forget to refit the ball bearing after the clutch pushrod. Refill the gearbox oil with 700ml mineral oil, 10 weight or an ATF rated to Dexron III. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
