footy14 Posted May 29, 2007 Report Share Posted May 29, 2007 okay, I'm wondering how much is involved with replacing the fork seals on my 1994 gas gas JT 250. I believe the forks are paioli's. I'm quite handy, so I dont mind undertaking a project. Any and all help would be great. Thanks! Quote Link to comment Share on other sites More sharing options...
footy14 Posted May 30, 2007 Author Report Share Posted May 30, 2007 Sounds fairly straight forward. Do you recall how much oil each leg requires? Thanks! Quote Link to comment Share on other sites More sharing options...
peterb Posted June 2, 2007 Report Share Posted June 2, 2007 Hi footy, Try 280 ml each leg, 5 weight. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
footy14 Posted July 29, 2007 Author Report Share Posted July 29, 2007 I started disassembling the forks today to replace the seals. I got the point where I have the forks off, the dust caps off, the circlip off, but I'm having a hard time removing the leg. Is it just a matter of using leg like a slide hammer and with some force trying to separate the two parts of the fork? I can't seem to find any other way to separate the two in order to replace the seal. Any help is great. Thanks Quote Link to comment Share on other sites More sharing options...
