Pwk 24mm Flatslide Carby
neo
Hi All,
Has anyone ever fitted a PWK 24mm FLATSLIDE CARBY to their Trilas bike?
I've fitted a PWK 28mm to my old Sherco. But was told, at the time, that the PWK 28mm, being bigger than the 26mm Dellorto, That the low-end power would not be as consitent....something to do with the speed of the air going through the Carb. :(
Anyway the PWK 24 looks very much like the PWK 28. But maybe a bit shorter in height. Which I thought might be good to fit to a Beta too.
What do you think?
Best of balance.
Neo
Hi
The smallest Keihin Pwk carb is the 28mm one, there are a few copy's of the keihin carb out there and some of them do a 24mm version for scoters and other similar bikes.
Personally I think the bottom end response is better with the Pwk 28 than the dellorto phbl 26.
I think a 24mm carb will limit the max revs by quite a bit.
Chris
Seem i once seen a listing for PWK 24 and 26 in a parts illustration and always wondered. I would think it was the same basic body with smaller bore.
I always thought a 24 would work well on a 125 or 200 if it fit!
That body barely fits the big bore Shercos and would be a real cram on a shorter 125 cyl. Although it has been done I hear. :(
