Pvl Ignitions?
fantic 300 pro
Put an internal rotor pvl on a maico 250 and it worked ok and was easy to install. Had even less rotating mass than the stock Motoplat button mag. (not good) Not sure if they make one for external flywheel setups though, like trials bikes. Do they?
Nice !!!!
Is that a modified Sherco kickstart I see.
And what is that BLUE joiner on the exhaust?
Kickstart is modified Gas Gas and the blue joiner on the exhaust is silicone rubber radiator hose which acts as a heat barrier and gives an amount of flexibility and vibration isolation to the alloy silencer.
Well thats the theory anyway :(
