billboat10 Posted June 3, 2007 Report Share Posted June 3, 2007 hi all was out today bike running good some times a bit hard to start but when running was ok then i cut it out to take a break and it wouldent start there is no spark at all plug changed kill dissconected any idea checked the wires all seem ok many thanks Quote Link to comment Share on other sites More sharing options...
sr34 Posted June 4, 2007 Report Share Posted June 4, 2007 same thing happened to my lads rev3 2003 last week seems a common fault on most betas it was the stator i will be sending my lads stator to steve at http://www.uk-motoplat.com/home.html who if you do a search on here seems to be the best at this stator rewind business anyway thats what was wrong with my lads maybe yours is somethig else do a search in the beta forum it is well covered as i say its a common fault ( Quote Link to comment Share on other sites More sharing options...
billboat10 Posted June 4, 2007 Author Report Share Posted June 4, 2007 yes i know steve had my techno one done sound job thing is when the stator played up on beta it did run but badly and never failed to start so aint sure about the rev one how can u test them Quote Link to comment Share on other sites More sharing options...
beta rev 3 Posted June 13, 2007 Report Share Posted June 13, 2007 hi, i had same problem on my o1 rev 3, sent it to Steve Hardaker at motoplat (alicante), got it back 8 working days later and its better than ever. woluld well recommend this guy... Phil Quote Link to comment Share on other sites More sharing options...
rick1 Posted June 14, 2007 Report Share Posted June 14, 2007 I had the exact same problem on my 2001. It was first hard to start then it just died.........turned out to be the black box tucked up under the tank. Apparently this is a common problem with that model year. The replacement boxes are "supposed" to be improved. Quote Link to comment Share on other sites More sharing options...
billboat10 Posted June 16, 2007 Author Report Share Posted June 16, 2007 I had the exact same problem on my 2001. It was first hard to start then it just died.........turned out to be the black box tucked up under the tank. Apparently this is a common problem with that model year. The replacement boxes are "supposed" to be improved. were did you get your box from and how much was it if you dont mind me asking as i dont want to have the stator done and find out its some thing else cheers Quote Link to comment Share on other sites More sharing options...
montman Posted June 16, 2007 Report Share Posted June 16, 2007 Do you not know anyone with a simular bike, that is running fine, so you can try various replacements to find the fault? Quote Link to comment Share on other sites More sharing options...
rick1 Posted June 19, 2007 Report Share Posted June 19, 2007 I had the exact same problem on my 2001. It was first hard to start then it just died.........turned out to be the black box tucked up under the tank. Apparently this is a common problem with that model year. The replacement boxes are "supposed" to be improved. were did you get your box from and how much was it if you dont mind me asking as i dont want to have the stator done and find out its some thing else cheers I got the box from BETA USA it was about $200 as I recall. Montman has a good idea though; if you know some one with a similar bike borrow theirs. It is, however, a son-of-a-bitch getting the box out and back in again as I recall. Quote Link to comment Share on other sites More sharing options...
